I need help creating a ladder diagram
ahillukka
Jul 2016
TRF
The process consists of a parking garage with an entrance and an exit door. The garage has 25 parking spaces. We assume the garage is empty at the beginning of the day. The parking garage manager starts the operation by pressing an NO pushbutton. As soon as the process starts, a green light turns on at the entrance of the garage indicating that parking space is available. The number of parking vehicles in the garage is constantly monitored as vehicles enter or exit the garage. To indicate that a vehicle has entered the garage, an NO pushbutton is pressed. Another NO pushbutton is pressed if a vehicle leaves the garage. If the number of parked vehicles in the garage is 23 or 24, the green light is turned off and a yellow light flashes continuously at the rate of one second on and one second off, indicating that the garage is getting almost full. If the garage is full, the flashing yellow light turns off and a red light turns on indicating that the garage is FULL. At this point if one or two vehicles leave the garage, the red light turns off and the flashing yellow light turns on. If additional vehicles leave the garage, the flashing yellow light turns off and the green light is turned back on.
For safety issues, the manager of the parking garage has decided not to allow any vehicle entering the parking garage if it is raining. When it rains, the red light should turn on at the entrance indicating the garage is full (even though it may not be full). The red light should be on for the duration of rain even if all cars leave the garage. When rain stops, normal operation resumes. Construct and incorporate a moisture sensor to simulate rain when the sensor is sprayed with salt water. At the end of the day, a NC pushbutton is pressed to stop the process and reset all counters.
What PLC system are you using for this?
For a program like this, most PLC systems will be constructed similarly, it would just be addressing details that would differ.
I would be using Direct-LOGIC-05, with DirectSoft5 software. First I must create it in LogixPro though.
Do you know how to create a latch circuit in ladder logic?
So press a button and latches on a "bit" until another button is pressed?
I'd suggest working on conditions for red light in another rung.
Then conditions for yellow.
And conditions for green.
For a flashing light, you may have to set up some timers. In siemens there is a handy "clock memory" feature of the CPU to have flashing bits (http://goo.gl/InSKLg)
I was wondering if anyone could help i am trying to use a SLC 500 with a 5/05 processor to set up an incremental encoder to a HSCE2 card? The card...
193
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
175
134
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
428
266
