panelview plus print screen to usb
stu
Aug 2005
England
784
Hi all
I have been asked if it is possible to copy all the screen shot (settings ) to a usb stick thanks stu
My bad. I understood you wanted to take snapshots of any screen during runtime.
The following technote answers the question Can I copy the MER application to/from a PanelView Plus using a USB drive, CF or SD card?:
TN25431 - Transferring (.MER) Runtime to a PanelView Plus with Removable Media (Access Level TechConnect)
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/25431/page/1
Maybe this other technote could be helpful:
TN 626794 - PanelView Plus 6/7 : Backup and Restore (Clone) options (Access Level TechConnect)
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/626794/page/2
In summary, PV Plus 6/7 has a clone function and it's intended for OEMs who want to copy the same image to multiple terminals. There's more details in the PV's user manuals (both PV6 and PV7).
Nhatsen
I like this idea now you have mentioned it ?
I could see a use for this if we was running the machine very well then press a print button to copy the line running settings
could you copy multi screen shots in runtime to usb with a click of a button thanks stu
I don't know about saving screenshots to USB, but if you just want to record the settings shown on a screen, you can do this with the DataStorePlus ActiveX control. Here's a thread from late last year where I was doing a similar thing.
Is it possible to log alarms on a USB drive from a PV600? Like trigger time and acknowledge time.
5,622
I've followed all the steps from Rockwell to use the KepWare UCONN driver to transmit ascii data out of the serial port on this PV+. No matter...
4,107
97
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
60
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
90
