Using ProWORX 32 on VMware Workstation
beddyteary
Sep 2016
Vancouver
Hi all,
I am trying to connect a Schneider TSX Compact PC-E984-265 to ProWORX 32 which I need to have in VMware Workstation for work on the field. However, whenever I tried bringing it online (initializing then stop/starting first) it always failed to detect it. I have already confirmed from an old DOS computer that the cable is not the issue. On ProWORX 32 I have already set the COM port to 1 and the VM settings to COM port 1 as well. On the PLC, the switches are set to pull-PLC and RTU first. Even with those settings I am still getting error messages. Please advise.
PS. Could it be that the Virtual Machine already reserved COM port 1 without me knowing? When I set to auto-detect physical com port it says COM 1.
try a loop back test - join 2-3 on the com port and use telnet to see if there is an echo.
Take a look at the IRQ's in control panel and if necessary re-allocate them on the virtual machine to suit the new virtual com port
Hello. 2 Days ago I was adding a timer on a Modicon Quantum 113/03 using Proworx. I forced the contacts on the shutdown logic of a compressor, to...
1,310
Not used proworx for awhile and just trying to reacquaint myself with its little oddities. I'm working with an existing system which has multiple...
4,585
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
75
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
133
