Delta DVP-SE communication with Keyence IV series
Saul Rivera
Sep 2016
Matamoros
Good evening everyone.
I've set up a network for an equipment I'm integrating. however as a way of saving up space/money, I tried to make a direct communication between a Delta DVP-SE PLC and 2 Keyence IV series Vision Sensors via Ethernet/IP; all I'm trying to do is to trigger both sensors and wait of either a pass or fail signal, and switch programs when needed; right now I'm doing everything through I/Os.
As you imagine, I've fail more than once
Keyence field nertwork manual says the only supported PLCs are their own KV series, RA Control/Compact Logix, and Omron Sysmac; however, not a month ago I saw an equipment running a GE Fanuc PLC and a Keyence vision sensor, this tells me there must be a way of doing what I'm trying to do, but right now frustration has drained all my ideas.
After all that whining here come my questions.
- Are Delta PLCs and Keyence vision systems able to establish communication through Ethernet/IP? if they are not compatible then I should ditch this idea already.
- Has anyone actually done this? if so, could you share your tips?
- Should I think about changing PLC brand? (The company bought this brand because is cheap).
Any tip/comment is more than appreciated
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,400
i have dvp 14ss2 plc and kgk inkjet printer .how to send data via rs232 com port,and if any sample program available please send .
2,084
i want to connect delta dvp sa plc to pc having scada running on it at a distance of about 100meter. i think rs232 will not be work on that...
2,113
Hello All, can anybody help with the Sample program of the Delta PLC and SCADA with modbus communication through RS485 port. Regards Amit
18
17,256
Hi all, I am using Delta DVP-SC Series PLC and LS iG5A VFD. I want to vary the VFD freq. with the help of PLC, using Modbus. Please help me how...
4,805
