Indramat servodrive
tom_stalcup
Jan 2004
fresno
461
I'm playing with an indramat servo drive system for the first time today.... Evidently it dropped its menu program on the operator interface. I have the software for it, and a couple of pages from the manual someone printed out a while back, but what I'm looking for are the key commands for the hmi that will let me get into the systems menu to tell it to get ready to receive the program. Any takers? A link to a manual somewhere would be helpful as well.....
Adding a little more info.... The hmi is called an "SOT", and the numbers on the back are SOT 02 E2A-CU, 248033, k46/94, and the sn is 247232-00429 A08.
Try this:
Press SHIFT and HELP together.
You should get a password screen.
The password should be SOT.
As an aside, those things are still around? /shudder.
That did the trick!
I dumped the program in, and everything is back to normal until the next time....
Evidently, this happens every couple of years.....
Thanks for the help!
The line has been running relatively unchanged for the last 10 years at this plant... I'm not sure if it was put in here new, or if we picked it up from someone else...... As time(and money) permit, I've been upgrading various parts of the equipment line(freq drives, processors, etc), but at the rate I'm going now, by the time the last outdated part is updated, I'll have to start over again.
Hello, what program is it used to connect with laptop a rexroth indradrive HDS02.2-W040N-H(verry old model), i'm guessing because its old so on a...
1,327
hi everyone! we need to update the program in the servo, a Rexroth Indramat PPC-R02.2N-L. The thing is we need the software for it, WinPCL...
787
Hi everyone We have a DKC11.3-040-7-FW with FWA-ECODR3-SGP-01VRS-MS firmware on programming module. Whenever we try to calculate commutation...
954
Hi all, Am new here, normally I work on OSAI and Beckhoff systems but I have a problem with some Indramat dkc11.3 drives that all display the...
1,425
Hi everybody, i have back up´s from Indramat Servo Drivers, but those file have suffix PAR. Drive1.par Drive2.par Does anybody know, which...
2,144
