CompactLogix to Siemens equivalent.
Elcan
Apr 2008
NC
935
Hi all,
I'm new to Siemens and I'm trying to find the Siemens equivalent for a CompactLogix L33ER.
I know Siemens use a different memory arrangement, so that's the part I cannot compare apples to apples. As a reference, a project in a CompactLogix can take me 300-500 KB.
Thank you!
How many IO and do you use any motion axes ?
I dont know how to convert that to a Siemens. If you theoretically made the same program in SLC500 or PLC5 (I know, not really possible) how much memory would it then take up ? You can multiply an SLC500 or PLC5 program memory by x1.5 to get the approximate memory requirement in a Siemens PLC.
I'm looking at the S7-1500 series, but I don't know if the CPU 1511-1 is not powerful enough or if the CPU 1515-2 is too much power for my needs.
You get two separate (2 NIC) Ethernet ports with the 1515
A 1513 has 1. I would think the 1513 would be fine because of the 300 KB code and 1.5 MB data
The CompactLogix L33ER has 2 Ethernet ports, but 1 would be enough for me.
That's where I don't know how to compare. I guess if I have a 300KB in the CompactLogix, the 300KB + 1.5MB in the 1513 would be enough.
I would like to have this answered. Then I can tell you which Siemens CPU will be powerful enough for your application. It doesnt have to be accurate. Just not a factor 10 off.
In my opinion AB is much easier to troubleshoot , software is easier to use
It depends on who wrote the code... if they wrote it with the troubleshooter in mind and some one looking at the code they wrote or if they only wanted to get the machine running
Compared to MicroLogix the 1214 is a beast.
If you make the leap, go for the PRO version of TIA.
You'll be set to tackle their entire range of hardware.
And, get the SUS.
I have a Siemens BW500 Weightometer talking to a AB Compactlogix over ethernet/ip, the comm link works fine but when the data is brought into the...
1,635
I am new to Siemens and we have to convert a CompactLogix program over to a S7-1200 PLC. We are having a hard time finding a comparable...
17
4,170
I have a machine that has a Siemens S7-300 plc in it. It also has an external machine connected to it that has a compactLogix plc in it. I would...
39
15,655
hi guys this is my first project using Siemens HMI, I got a problem to setup comunication between AB PLC and HMI, when the HMI is in the run...
3,634
Hey guys & gals, Did a quick search and couldn't find anything, so.... I'm having a terrible time trying to get a Siemens MP277 to 'talk' to an...
18
6,399
