Kepserver dnp3 master
Mike_ant
May 2017
USA
hello guys
i'm trying to connect kepware server to a foxboro rtu (simulation purpose /foxrtu station with isagraf 5.13) through dnp3 master ethernet .
i'm working on a virtual windows xp machine and everything is installed right there .
when i run quick client in order to see data i don't get anything .
any suggestions and infos from who have done this ?
I can't make out your picture.
When you talk to a OPC server, you can either use static or dynamic tags. The static tag has to be configured in Kepware, right click on device and select New Tag to create one. The OPC quick-client can then browse and view the value of the static tags.
i know that i create static tags and server creates dynamic ones
these are pictures i attached earlier (sorry resolution changed by forum )
http://imgur.com/a/7Wgy3
as you see i created two static tags just for test and it says unknown values and bad quality
thanks in advance
It's hard to say, all I can offer is the SOP for troubleshooting any comm issue; troubleshoot the different layers, physical, network, and so on. The problem with DNP is there aren't any free DNP slave or master simulators out there, unlike modbus.
Maybe try to get Triangle Microwork's Gateway trial and use that as a master to see if you can poll, if not, they you troubleshoot the slave side or check on your cable configuration.
is it possible to read those data via a web server ? visual studio with dll or so collect those data then transfert to a web server
any idea ? drivers ..etc
I would ask what is your main objective?
If it just to verify the RTU DNP Slave fuctionality, then get another DNP3 master program like TMW Gateway to test it. TMW also can act as DNP3 slave so you can test the OPC DNP3 master against it.
my goal is to read those data in order to make an interactive hmi
via intouch or visual studio
for simulation purpose
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,065
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,469
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,507
Hello. I have an existing Wonderware system connected to existing SLC500 PLC /Flow Computers / RTU as shown in the attached Pic. And Existing...
1,694
I have ControlLogix L71 on ethernet. I want to send data to another Third party device using Kepserver. DO you have any idea how much data can I...
2,457
