bbishop108
So I have some programming experience with using the FSC instruction in Logix 5000, and it works well for my application. I noticed that there is not an FSC instruction available in the Logix 500 platform (Micrologix 1100), as such my question is does the SQC instruction work at all like the FSC in Logix 5K?
My intended goal with using the SQC (as this is what I am doing with the FSC instruction in Logix 5K) is to search through the available part numbers. If the pn exists then its settings are loaded, if it is not available then it would require manual entry and would store the new part data into the next available spot in the part number data file. Thanks
