sparkyinak
Here in the United States, ferrules are not required to be used on stranded wire unless specified somewhere. Like for example if the panel were to go overseas or customer specification calls for it. When it is optional, I find it hard to validate an argument to use ferrules.
I understand why they are used in order to ensure all the strands are nice and straight and securely under the terminal to ensure a quality connection. At the same time, missing or damaged strands can be easily hidden inside the barrel of the ferrule. They can easily add $1000 of added cost to a larger panel in material and labor. On larger orders like multiple panels, that can be several thousand dollars.
How would one sell or validate the necessity of using ferrules to warrant the added costs when good craftsmanship, which I can presume we are all craftsmen, will do the job as well without the additional costs? As a supplier of service rather as a panel vendor or as maintenance personnel to an employer, the bottom dollar has to be watched like a hawk in order to stay in business. We can not always do or use what we want because its preferred, or "that's just how we did it" mentality works in a successful business.
Thoughts?
Thoughts?
