OMRON CS1W-CN226 (CS1W-CN626) need help!
inverter
Guest
I
Hallo boys,
Can I find anywere schematics and pin-out of OMRON serial cables CS1W-CN226 (CS1W-CN626) or description of CS1G PLC peripheral port pin-out description?
Buy the cable and be done with it. It is quite inexpensive. You would go crazy trying to solder the peripheral port plug.
I have this cable!!! I need pin-out for connection test ( I think cable is damaged :( )
I think cable is damaged because my technician close the door of electrical box then one end of cable was inside of box(connected to PLC, but another outside (connected to my laptop).Thank You for CS1W-CN226.zip.That's real help!
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,915
We want to purchase a high-speed data recording module CS1W-SPU01-V2 for CS-series PLC and still wondering what to buy the software. We definitely...
1,985
Hello, anyone have the pinout for the Omron cable cs1w-cn118? I am trying to see the different between CS1W-CN226 cable (programmer cable)...
13,795
IN MY COMPANY WE ARE USING OMRON CS1W-DRM21V1 MODULE AS A MASTER UNIT. THROUGH DEVICENET WE CONNECTED DRT2-ID16 & DRT2-OD16 INPUT & OUTPUT...
2,006
