Carlo Gavazzi WM14-96
Ptolemies
Apr 2017
Manila
Hi guys. I have a power meter (Carlo Gavazzi WM14-96) communicated to the PLC (AB CompactLogix L35E) via profibus. I have gotten the values, but I don't know which parameter is which. I can't also find anything in the manual. Does anyone know how to read the values? Thanks
EDIT: Even if you can link me to what values each parameter from the GSD files. Thanks
I was told that there is a function block for carlo gavazzi power meters in siemens, but I can't find it anywhere. Does anyone have that, can you message me a screenshot so I can just study it. I am not very familiar with siemens programming, I may ask too much questions once I get my hands on this FB. Thanks :)
So what you have done allready on Siemens side.
On hardware config you need to configure WM14 station with GSD file. (I assume, you have allready done that)
Next you need to drag and drop modules to station (there is Phase 1 values, Phase 2 values etc. which you can choose)
Then look PDF
http://www.support-carlogavazzi.se/downloads\Controls\Profibus modules_V1R0.pdf
PDF have offset addressed sayed for every module you have choosed.
You need to look IW (PIW) addressing selected for WM14 and copy values to DB-addresses on PLC program
Then look PDF
This is exactly what I need. Thank you very much!
Hello! I have made connection in TIA portal with an energy analyzer(Carlo Gavazzi EM26-96) using Modbus RTU. What I am mainly looking for is...
810
Hello, We're trying to connect to carlo gavazzi wm14-96 using tia portal. But we couldn't find any gsd file for it. Could you please help? Thanks
1,141
Hi, I just need some help. i've been trying to communicate a power meter to rslogix5000. carlo gavazzi wm40-96 with comm module MC EI ETHERNET/IP...
2,984
Hi, I'm working on a PLC project including Duplines from Carlo Gavazzi, the specifik model-number are: Type G 3496 0003 I'm working on two...
2,174
Hi all, I have a machine with a PLC ELC2001 from Carlo Gavazzi wich is stopped and I need to chech the program but I don't have neither the...
2,704
