KB4093108 causing issues on some Rockwell computers
Stonent
Jan 2015
Texas
We have at least a dozen or so computers that use the Rockwell applications to talk to AB PLCs. We've noticed that a particular Microsoft Update https://support.microsoft.com/en-us/help/4093108/windows-7-update-kb4093108
Causes a sudden reboot on about 3 of the computers when booting up. This reboot does not generate a Windows dump file or even a bluescreen (even if it's set to block automatic reboots)
So we have to avoid that particular update even though it prompts to install. Has anyone else had issues with that update?
So far, the computers have the following in common
32Bit Windows 7
Has Rockwell software installed.
Here are the specifics of what 2 of the affected computers have installed.
PC #1 FactoryTalk Activation Manager 4.01.00
PC #1 FactoryTalk Diagnostics 2.90.00 (CPR 9 SR 9)
PC #1 FactoryTalk Services Platform 2.50 (CPR 9 SR 5)
PC #1 Redundancy Module Config Tool
PC #1 Rockwell Automation USBCIP Driver Package
PC #1 Rockwell Windows Firewall Configuration Utility 1.00.08
PC #1 RSLinx Classic 2.59.00 CPR 9 SR 5
Core2Duo with 4GB of RAM
PC #2 FactoryTalk Activation Manager 4.01.00
PC #2 FactoryTalk Diagnostics 2.90.00 (CPR 9 SR 9)
PC #2 FactoryTalk Services Platform 2.60.00 (CPR 9 SR 6)
PC #2 Rockwell Automation USBCIP Driver Package
PC #2 Rockwell Windows Firewall Configuration Utility 1.00.08
PC #2 RSLinx Classic 3.60.00 CPR 9 SR 6
PC #2 RSView32 7.60.00
Core I3 with 4GB of RAM
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
150
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
289
I am working with a 1768-ENBT and I was able to connect to it through my laptop. My laptop IP is 192.168.1.10 subnet 255.255.255.0 and the PLC...
1,585
Good Day everyone I am currently writing a program for a 4 cylinder press i have it mostly done. just have one issue with my program where i...
18
3,961
After watching The Universe is Hostile to Computers from Veritasium, I suddenly remembered a lost weekend years ago trying to reproduce the same...
4,420
