Jumper Bar for Micrologix 1400?
FNC
May 2010
NJ
84
All,
It is a pain to have to wire together all the commons for the relays outputs on the Micrologix 1400.
Is there a jumper bar that we can buy?
I know there is for Controllogix series but I do not see any for the Micrologix.
Thanks,
FNC
Wow... and I thought I was the only one :oops:
I thought about manufacturing some if there was a larger interest, let me check on the cost if there is not some available on the market
The spacing seems to be 7.5 mm. I cannot find any comb jumpers with thin enough teeth.
I wire these all the time and jumpers would make my life a lot easier!
So would just the comb style work or would you need to go from the upper to the lower also?
I was thinking about the 1766-L32BWA (first) on the relay outside a jumper that would join DC0-DC4 and also DC5 and DC6 and as one piece ? or just DC0-DC4, that would be easier
You are right. Most of the commons are on the bottom but a few are on top.
I think just for the bottom ones would be good. I can then put a wire from a terminal on bottom row to the top row.
dmargineau,
Nice find!
I searched quite a bit and had not found these. I will buy 1 and try it.
FNC
They are accessories for the venerable AB NEMA 1492 terminal blocks; the blocks are still available although I'd probably had tens of thousands of them replaced.
I frequently use the jumpers on the Line Side of adjacent NEMA fuse and terminal blocks.
Well, I tried the Allen Bradley ones with 7.5 mm spacing but they did NOT work.
The teeth are a bit too thick.
It is annoying that Rockwell does not make anything for this.
Rather than bumping an old thread http://www.plctalk.net/qanda/showthread.php?t=116475 Has there been any progress on these?
1,539
Does anyone make a brush on insulation to put on the exposed end of a terminal strip jumper bar that has been cut down to size? Although these...
5,203
Can someone explain the jumper between the elements? Does it do anything? See attached jpeg.
694
{Old Indramat guy here} (*) How do you 'jumper out', logically, a drive on a Kinetics 6000? For example, I have a Power Module (Node 20) and...
1,784
Hey everyone, Ran into a bit of a hiccup today, we (I) forgot to order the CJC kit for a 1756 ControlLogix thermocouple card, and we need some...
2,176
