1769 l24er qbfc1b high speed counter
PANA0516
Jan 2013
sanford nc
i need some help with this configuration .1769 l24er qbfc1b I benn try configurated this counter for my encoder but i cant see nothing
Local:4:O.Ctr0En
Must be set to 1 for Counter 0 to run. You can do this in the Controller Tags table or logic, etc.
This is the one I remember struggling with.
Whilst commissioning a system using a CompactLogix 1769-L24ER-QBFC1B we have accidentally shorted an output to ground causing the output to stop...
2,707
Hi I'm newish to the PLC world and have a little test/learning rig put together at work. I have a micrologix 1100 and a 1769-L24ER-QBFC1B, I also...
1,590
Hello, I have a prox switch switch plugged into my embedded counter in terminal A0+ and I'm trying to see which input I need to use to monitor...
2,052
Hello, I want to understand what each terminal does on the Embedded High Speed Counter on the 1769-L24ER-QBFC1B PLC? I read the manual, but I...
2,999
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
287
