Gray code encoder on SLC 5/05
Joe Smalling
Dec 2004
Can anyone direct me to a programming example for using an AB 845D encoder into a SLC 5/05? I have a very simple application to write that uses machine position, but I have never used an encoder in AB. If someone could point me to a sample program it would be very helpful.
AB 845D encoder to TTL input module.
grey code to binary
this SLC 5/05 program converts grey code to binary
but be sure to mask off unused inputs before moving the input word to N7:0. ,N7:1 is your binary value.
845d To 1746-ig16
Hello,
i need to connect a 845D encoder to 1746-IG16 SLC500.
can any one provide some technical documents (Wiring diagrams,Pin configurations...)
Thanks for you support
Hey guys, Although I've poured through this forum for help in the past this is my first post. I am looking at replacing obsolete Baumer IVO...
2,000
First time I have used an absolute encoder and it is definitely:banghead:. I have a Siemens 6FX2001-5FN25...
21
6,138
I am migrating a PLC-5 to CLX. I do not have the option of changing out the existing encoders (845D-SJHZ25AGCW4). 8-24v DC, 256...
1,619
Hi I have a question about a gray code absolute 8 bit encoder. The encoder is connected to 8 inputs on an Allen Bradley PLC. if you turn the...
2,296
Any recommendation on using a gray code encoder as input to a compactlogix PLC to trigger a digital input every 15 degree position on a rotary...
2,788
