Rod
If you are new to RLL (relay ladder logic) programming and are attempting a REALLY big project, I would recommend ordering the ‘SMART BRICK’ from your dealer.
The SMART BRICK has all the possible functions and calculations pre-programmed. That way all you need do is discard the few you wont need. A MUCH faster method when programming a ladder of 1000 rungs or more!
Also, when you have a ladder with 100 to 1000 rungs or more an important safety point here:
As the rungs of a ladder are spaced one foot apart, a ladder over 100 feet MUST have supporting guy wires.
European ladders, however, are METRIC and, therefore have different requirements.
NOTE - These guy wires are, by nature, pre-grounded, and help the technicians in installation and trouble-shooting.
Ladders over 100 feet also MUST have red warning lights spaced at intervals to warn aircraft. The top must have a flashing red light. Your first rung should therefore have a self-resetting timer to flash this light. Generic code for this, in PDF format, is available somewhere on this site.
Some programmers will add ‘elevator code’ for ladders over 250 feet to help speed up a technician’s future trouble-shooting.
Check with ElevMike on this as he has the proprietary elevator code that he will not give you.
When you have finished the last rung, it traditional here in the US to have a ‘topping-off-ceremony’ where a small fir or pine tree is attached to the top rung.
This being close to Christmas, I personally would add more flashing timers to drive lights on the tree – just my thoughts here.
Some ladder programmers, who shall remain nameless to prevent embarrassing myself, like to boast about how high their ladders are. They tend to insert NOPs into their code.
The NOPs are quite useless, as is this post.
Merry Christmas ya'll
