rs5000 emulator
rscott9399
Aug 2017
in space
114
Question on the emulator for you guys
Has anyone got the emulator to speak to any hardware?
For example, i am writing some preliminary communications stuff to go between an ML1400 and an L33.
I have the Ml1400 but no L33 yet.
Will the emulator read messages from a physical network?
I dont care to much about sending messages but it would be nice to at least try and go one way.
If i started sending the emulator msg statements using the IP of my laptop the emulator is running on, you think it would work?
I know the emulator does not really have an IP
Just an idea
yep, just downloaded it
It says softlogix 5800
Will get it installed. Need to get this up and running. Any suggestions much appreciated.
It's essentially Emulate with an Ethernet I/P adapter. You can connect Ethernet I/O to it (like Point I/O), upload/download over Ethernet, Produce/consume with other Ethernet PLC's, etc.
interesting, it doesnt like emulate. it just told me i cant install soft logix 5800 unless i uninstall emulate
Yup, one or the other. SoftLogix is great, but I don't believe Rockwell is keeping it updated anymore, so stuck at v23 I think.
i have v23 up and running now.
for some reason it wont let me set the IP on the ethernet ip in the chassis.
its stuck at 0.0.0.0
hmmm......................
if anyone is interested, i found the answer. V23 of studio 5000 is the last version apparently that will run Softlogix.
However, when i add the ethernet ip card it will not allow me to change the IP address to anything other then what my computers IP is or 0.0.0.0
Not sure where to go from here.
End goal is to get the ML1400 which i have physically to send some messages to Soflogix controller using MSG statements
if anyone has any ideas this morning i much appreciate it.
Someone recently reached out to me on github with a similar SoftLogix issue. They basically said this:
human said:
Not sure why it works now. The manual said disable UDP packets in RSLinx so I did and rebooted. It now had my IP address I assigned. I enabled UDP packets, rebooted and it still worked.
well i have setup a bit more, according to the manual, unless you have more then one nic on your PC, the virtual Ethernet card will have the same ip as your machine.
I have everything connected now but for some reason the msg block in my physical ml1400 says the host is refusing the connection.
So something is obviously screwed.
All, Just started to work with Vijeo Designer 6.1.4 SP4 and was wondering if there is a way to point their simulator to RSLogix5000 emulator...
3,151
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
368
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
105
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,209
Hey folks I was wondering how one puts shortcuts on the logic display for instructions. A few weeks back another programmer added them for me...
974
