I want to gather data from several S7-200 (+15).
Ths is the first time I will be doing networking for PLC, I have little experiece with Computers
the attached picture (JPEG) shows three options.
I have a couple of questions, to help me decide which one would be good choice, as I dont want to mess-up this project!
HARDWWARE used is
15units of S7-200 PLCs, acting as slave.
1unit Master to gather 4 Byte of data from each slave.
15units of tp-070 each attached to the slave.
A) The siemens book says that the TP-070 does not work with another master on the network!!! can someone pls. shed light on this? or how I can by-pass this restriction.
B) considering the above environment, should I use the 1st option in the picture?
because I recall there is a restriction in the number of network nodes in case of PPI network
or would I have to go for PROFIBUS or a ETHERNET based network?
Any other restrictions / advantages you think, may help me select the right product.
HARDWWARE used is
