RSView32 Wallpaper back to object
harryting
May 2002
Puget Sound
2,595
The title says it, I was clicking like a madman trying to select this graphical object with no success only to realize it has been converted to "wallpaper". I got a bad feeling that I am SOL but just want to confirm it.
-it's an existing project and i wasn't the one who converted it to wallpaper, so UNDO won't work.
While I am on the subject of RSView32, a few more questions for you RSView32 experts:
* Why would someone use ActiveX Textbox instead of String Input? I can't think of a good reason.
* Similiar question; why use ActiveX Commandbutton instead of RSView Button?
* why buy and pay for RSTool to use Vessel Control only to display tank level?!
-I got a bad feeling that this project was done by a VB programmer with no experience in RSView.
for the "wallpaper-that-would-not-die" problem:
on the main menu at the top, select Edit > Wallpaper > Unlock all wallpaper ...
see if that helps ...
I know this may be a little choppy,
But, I don't have my laptop in front of me.
At the top of the screen(the one that says File,Edit,View and all that)If you check them all, in one it will have a bar that says something like, "convert to wallpaper" and one that says something like "undo wallpaper" I assume you want to undo the wallpaper. It will however, undo all of the wallpapers in the program (which isn't anything too bad, unless you're riding a razor's edge on memory)
Hope this helps.
My apologies though, Harryting
I was incorrect in stating that undoing your wallpaper would undo the whole program, it only affects the .gfx file that you're working on.
Thank you Mr. Beaufort
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
391
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,923
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,450
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,313
