Very urgent - toshiba ex series
Daniel Mendes
May 2017
Albufeira
I just ordered a handy programer TOSHIBA HP-100 but i have not the cable to make connection to the cpu PU11A. Please someone help me with the cable diagram because i don't want to do nothing wrong.
Please reply urgently. Thanks in advance.
Daniel Mendes
Hello Daniel:I am not familiar with this PLC. I have tried to dig some documentation for it, but I cannot find the wiring for the handy programmer (HP). First of all, is your PLC the one mentioned in link below? It says the communication with the HP is RS232.
https://www.mssc-direct.toshiba.co.jp/docsys/tseries/member/pdf-e/TS01-E034_3rd.pdf
However, the image of this PU11A device shows an 8-pin connector that I do not recognise. Is this the one you need wiring diagram for?Please have a look at the two images I am attaching herewith.
I cannot find the specification for this cable, but based on the information I found in picture below, I found a number of sites that claim to be able to provide the cable for the handy programmer.
Document:
https://www.mssc-direct.toshiba.co.jp/docsys/tseries/member/pdf-e/TS03-E025.pdf
Potential cable suppliers:
http://www.toshibaparts.net/toshiba/tcj905-cs
https://secure.transtronics.com/TCJ905-CS.htm
https://www.radwell.com/en-US/Buy/TOSHIBA/TOSHIBA/TCJ905-CS/
https://www.daxautomation.co.uk/part/toshiba-tcj905-cs/220016
I hope this information is helpful.
Hello Alfredo
Thanks for your prompt reply.My HANDY PROGRAMER is a HP-100 and is different from the HP-911 and the communication is RS485 and not RS232.The plug is FCN361 in both sides.
I'm going to check the cable TCJ905*CS to see what are the connections and pinout.
Thanks again for your hellp.Best regards.
Daniel Mendes
Hi Guys please someone help me and take it as ugent requirement for my project, I am using Step-7, CPU 412-2 here and the logic that i have to...
1,791
1,783
To handle the case where incrementing the minute will cause a roll over, Lets say system time = cd:59:ab:xyz when pulse arrives. if xyz < 998...
2,203
hi guys, please help me out from the below mentioned problem as soon as possible as its very urgent for me and the FAT in coming days. I am...
2,762
4,169
