Siemens-WinCC RT Professional v15.
hkazan
Jan 2021
lebanon
Hello,
I'm working on TIA Portal v15, and Wincc RT Professional. My Pc works on Windows 10 Pro, and I have installed SQL server 2019.
The problem I'm facing is that QSL server (Wincc) is not running or is not able to start, so I can't compile or run my SCADA design.
Wincc RT Professional gives this error : Compilation not possible. The "WinCC" instance is either not running or not available.
I tried to start SQL server (Wincc) from SQL Server Configuration Manger, but it won't run.
Any help, on this problem?
Thanks....
Does your project run or go to run mode on the development PC?
WinCC RT software is just for the pc without development
I designed and programmed the PLC, and HMI (KTP-1200 comfort). It was compiling and running normally. but when I add the WinCC RT Professional, all the project stopped due to the error mentioned above.
My understanding is that WinCC Professional V16 requires SQL 2016. My guess is an older Portal version (V15) wouldn't like a newer SQL version (2019).
I'd recommend calling tech support to see if you can get that sorted out. I have a feeling it would require reinstalling WinCC Pro at the very least, possibly uninstalling SQL 2019 as well.
Does any one have a link to download WinCC RT Professional v15 + Crack???
19
8,137
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
302
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,556
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
673
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,573
