Convert PBA to FTV HMI
nogz
Oct 2022
INDIANA
Hey all,
First time poster...
I'm trying to convert a PBA to FTV but keep running into the same error... "Failed to open project:"
I've attached the file. Can someone try it for me?
it converted with errors. Not supported features. Bit arrays, LSB, etc. So, you'll need to fix that in FTVME
To convert you need to make a NEW project in FTVME. Then use the Import button, select PBA file type to import and then select pba your project.
cwal61,
I attached an image of the steps I took to try and convert it.
I haven't made it far enough to fix in FTME.
Just a thought, try putting your PBA on the desktop and converting from there. FTView may have a problem with the Z: drive.
Not sure it was an issue with the Z: Drive per say, it most likely was the length of the path selection. I have seen that issue before. Just by relocating the file to shorten the path made a difference. Anyway, Glad you got it to work and good luck with your project.
Can someone Pleease, convert this panelbuilder32 v3.61 file for me?
1,405
Can anyone convert this pba file for a panelview 600 to a pdf for me, just had someone break a screen and need to convert program fast. Thanks Cowboy
2,432
I only have Panelbuilder 1400e Software can I convert a PBA file to PBV. Or does any body know if I can demo a program that will enable me to view...
2,298
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
320
