Idec Micro-1 Data cable pinout required
John Cairns
May 2002
Edinburgh, Scotland
I am trying to teach myself a bit of plc programming with a Idec Micro-1. I have the hand held programmer for this but would like to connect to my my PC and use WindLDR software. I need to know the pinouts to make a cable also do i plug into the same port where the handheld is plugged into or do i use the 10 pin connector which is also on this PLC.
:confused:
regards,
John
The Idec Micro 1 must have a cable with a built in converter, you can buy these from NR&D for around $195. The cable will plug into the RJ11 jack on the PLC just as the handheld does. Idec also brand labeled the Micro 1 for Squard D. So, you may find a cable from either your Idec or a Square D distributor, but the NR&D cable is much less expensive than all of the cables and converters you buy from Idec or Square D.
Hmmm.... IDEC says the list price for the FC1A-CLA cable is $85
Newark Electronics sells it (P/N 50B4189) for $96.66... Go figure!
You may also look into cables for HMIs... KEP sells a cable (with converter) (P/N SMICIDEC-M1) to connect a Micro1 to their HMI, which is RS-232. This might be a cheaper alternative. And don't forget, there's always Ebay! :D
-Eric
P.S. My underlined text above are hyperlinks!
Eric,
While you are correct on the cable price as I recall this does not include the converter which is seperate. Once you add the converter the cost for communications is much greater than the cost of the NR&D cable. As your suggestion to use KEP's cable and adaptor this might be a option, as well as your E-bay suggestion for John to try.
Sid,
Though ALL replys are ALWAYS appreciated!!!, the QuickPanel cable diagram won't do John much good as he still would need IDEC's link adapter, which is way overpriced. Nice of you to offer up this info anyway! :cool:
Mike,
From IDEC's FAQ Description(<-- link), I would think that this cable DOES include the converter since they say "From the Micro1 to the computer", but I would definitely make sure it WAS included before I ordered one! ;)
-Eric
Same Question, but with MicroSmart
Hello,
Pretty much the same deal, new to PLC's but I need to get familiar with them as fast as possible. I have a computer with WindLDR ready, and I have the MicroSmart PLC, but everything I try doesn't work.
Any obscure ideas are welcome, my company has access to just about anything that will make the network function properly.
Thanks!
Josh
I dont get it.
Some years ago, I got my cable and converter, and software with an Idec "starter kit". I spilled about $150.00 for it all, at the local Galco store. It even included a Micro 1 to boot.
What happened?
Another Question
I was wondering if anyone would know the pinout for FC4A-KC4CA, for 485 or 232, my boss was tinkering and took the end off of ours.
Thanks!
Josh
Josh,
Your part no. dosnt match up with anything I have, so I did a search on Idec's website, and came up empty there too. Your boss is in BIG trouble now.(n)
Yikes. I'll have to check that part number, I couldn't find it on their site either. I think it was just a 9-pin connecter on one end and a DIN (i believe) on the other.
I'll keep looking, and thanks elevmike =)
I still can't get the MicroSmart to talk to my PC. The only thing I can see to do is make a custom cable, with a 9-pin end and just wire the other end to the A B SG input.
Does anyone know if this will work?
Josh
Hello, I am a new member. I use an old automatic wood oven. Its controlled with a IDEC Micro-1 PLC. There is now a mistake. When I switch on the...
1,106
Joe here from Palm Gaming- hoping to find some help here- we run a custom made heat press- we make ***** chips for casinos- the press has the orig...
7,341
I have a machine that is new to our plant that has a Idec Micro 3 FC2A-C24A1 processor. Does anyone know if WindLDR ver 4.2 will talk to this...
3,682
I am working on a project and was curiouse if anyone knew or knew where i could find the schematics for the Micro-1 and Micro-1 expansion plc's...
1,983
Hello there! Need help for micro-1 idec plc interface pinout. Units were obsolete and it seems quite hard to find means to access such PLC...
3,438
