S7 - using Arrays with Multiplex Addressing in ProTool
RMA
Sep 2004
North of Hamburg, Germany
2,052
Since I've suddenly got a couple of weeks spare time due to late delivery of the chargers, I've decided to go through my ProTool project and try to change the addressing of the capacitors in the fault screens from individual addresses in the Multiplex addresses to calls to an array. There are 532 capacitors in the system and since there are two different potential fault states they are each addressed using two different symbols. If I can get this working, I can thus replace 1064 symbols with 42 arrays, which solves my problem with too many variables in one hit.
However, after reading the Help files for a few hours, it's becoming obvious to me that I haven't a clue where to begin. What's more, I'm not even sure what questions I need to ask yet, but these are the ones I've thought of so far.
1) Can I do this entirely in ProTool
2) If I manage to create an array in ProTool when I access different points in the array in a Multiplexed address with the form Cap_01_Mod_05[1], Cap_01_Mod_05[2], etc. does each access count as another Symbol - if so, we're back at square one!
3) Have I not understood how to use Arrays in ProTool, and it can be done, but not like this - if so, how?
4) As has been suggested before by S7Guy amongst others, one way to do it would be to do the array handling in the PLC and map the result to a single variable in ProTool, rather than using the Multiplex Addressing. If I go this route (and it looks like it might be the easiest, although I'm a little worried about what it might do to the cycle time), how do I populate the arrays? For one situation I'm reading the input signals directly, for the other, I'm reading the results out of a DB.
Any pointers to get me moving in the right direction will be most welcome!
Cheers
Roy
From what I gathered, you could store the information in around 34 DWORDs.
You could bring the 34 dwords in, and have 32 bits ( 16 capacitors) for each word. You could then cycle through the 34 words via a mulitplex.
I believe in arrays, you can call them out in scripts, using square brackets with an index ..... temp = varray[23].....
Depends on the overhead again. I try and use my PLC as much as possible, and try to bring the packets in implicitly,so that when I access the bits, the are alligned with the item I want.
Do you want to send you project over to me? We both seem to be the ones dealing the most with Protool on this forum
WinCC Flex
I do this in WinCC Flex. I read in the DB from the plc then I trigger a script to run on change. I assume you can do the same in Protool
'This Script copys HMI_MUX_Input_1 to internal bool tags
'The plc writes the one variable and the HMI deMux's.
'This reduces the number of Power tags by combining all the bool's into one 16 bit word
'Bit 0 = HMI_Filter_Running
'Bit 1 = HMI_Light_Curtain
'Bit 2 = HMI_Pump_In_Manual
'Bit 3 = Eject_BlowOff_Sol
'Bit 4 = quick_move_equal
'Bit 5 = ram_start_equal
'Bit 6 = table_eject_pos_equal
'Bit 7 = table_fill_pos_equal
'Bit 8 = table_underfill_pos_equal
'Bit 9 = Lift_fill_pos_equal
'Bit 10 = ram_target_pos_equal
'Bit 11 = ram_target_ton_equal
'Bit 12 = ram_slow_dist_equal
'Bit 13 = ram_comp_speed_equal
'Bit 14 = die_float_dist_equal
'Bit 15 = test_time_equal
Dim hold, remainder
hold = SmartTags("HMI_MUX_Input_1")
'bit 8
remainder = hold Mod 2
hold = hold \ 2 'divide by 2 and remove remainder
If remainder = 0 Then
SmartTags("table_underfill_pos_equal") = 0
Else SmartTags("table_underfill_pos_equal") = 1
End If
'bit 9
SmartTags("Lift_fill_pos_equal") = 0
Else SmartTags("Lift_fill_pos_equal") = 1
End If
'bit 10
SmartTags("ram_target_pos_equal") = 0
Else SmartTags("ram_target_pos_equal") = 1
End If
'bit 11
SmartTags("ram_target_ton_equal") = 0
Else SmartTags("ram_target_ton_equal") = 1
End If
'bit 12
SmartTags("ram_slow_dist_equal") = 0
Else SmartTags("ram_slow_dist_equal") = 1
End If
'bit 13
SmartTags("ram_comp_speed_equal") = 0
Else SmartTags("ram_comp_speed_equal") = 1
End If
'bit 14
SmartTags("die_float_dist_equal") = 0
Else SmartTags("die_float_dist_equal") = 1
End If
'bit 15
SmartTags("test_time_equal") = 0
Else SmartTags("test_time_equal") = 1
End If
'bit 0
SmartTags("HMI_Filter_Running") = 0
Else SmartTags("HMI_Filter_Running") = 1
End If
'bit 1
SmartTags("HMI_Light_Curtain") = 0
Else SmartTags("HMI_Light_Curtain") = 1
End If
'bit 2
SmartTags("HMI_Pump_In_Manual") = 0
Else SmartTags("HMI_Pump_In_Manual") = 1
End If
'bit 3
SmartTags("Eject_BlowOff_Sol") = 0
Else SmartTags("Eject_BlowOff_Sol") = 1
End If
'bit 4
SmartTags("quick_move_equal") = 0
Else SmartTags("quick_move_equal") = 1
End If
'bit 5
SmartTags("ram_start_equal") = 0
Else SmartTags("ram_start_equal") = 1
End If
'bit 6
SmartTags("table_eject_pos_equal") = 0
Else SmartTags("table_eject_pos_equal") = 1
End If
'bit 7
''hold = hold \ 2 'divide by 2 and remove remainder
SmartTags("table_fill_pos_equal") = 0
Else SmartTags("table_fill_pos_equal") = 1
End If
@jwall,
Sure, I can copy the project over. Need to do it by e-mail though because it's just over 3 MB. Can you PM me your e-mail address?
@CharlesM,
Ouch, I'm not very fit in Visual Basic. All I know is that it is possible to script in VB in ProTool, but I've never tried it. I guess with WinCC Flexible creeping up on us, if it's anything like normal WinCC where half the programming seems to be done in VB, maybe I better resign myself to learning it! :(
I'll have to have another look at your program tomorrow, it's a bit heavy for me at this time of day! :)
Roy
Charles,
Win CC Flex allows you to make arrys of tags. Each array, no matter how big, only counts as one power tag.
Isnt that script of yours redundant ?
Somewhat new to Schneider (aka Modicon) PLC's and the Unity Pro XL programming software. I have a TSX P57 6634M PLC. I would like to take an...
3,202
I ran into a slight problem when doing some work. I found the solution to the problem, but, the two lines of code read the same to me. One works...
2,729
0 down vote favorite I am using B&R Automation Studio on a simulation PLC. I am...
1,533
I created a tag called rack_and_contents which is a 13,1 array. I want to put into this array, a rack # (int) and its corresponding contents...
2,929
I need help in creating Arrays in RS5000 v17 using udts. I am very new to RS5000 and do not have the savy to pull this off by myself. I need to...
3,841
