dash
A recent challange I worked out tonight was getting a float, which represents the number of counts for an indexing drive to move, split into a low and high 16 bit word. This example is for a PLC5 so it will also work for a SLC, but there may be some better math choices for a SLC.
Anyway, I am sure someone could probably do a cleaner job, but I never sould find an example I could follow. Attached is my attempt in a PDF file. The code has been fairly well checked, but if you use it check it out yourself before applying.
Darren
By the way. It will have an accuracy of +/- one count. For me that was good enough.
Darren
