single phase ac motor
ushakkal
Dec 2002
palghar
please any one can tell me how the value of capacitor is calculated for start winding of 220 v ac,50Hz single phase ac motor?
thanks in advance.
You can do a ton of math trying to figure the right size capacitor and still have to use some trial and error. The easiest method I have found is have a capacitor of the proper voltage rating(at least line voltage) connected to the motor.
(1) Make available both capacitor leads and both sides of the start winding, then apply power to the motor with a locked rotor.
(2) Using two volt meters, with meter #1 read the voltage across the start winding and with meter #2 read the voltage across the capacitor.
The voltage across the capacitor should be 10% higher than the voltage across the start winding. When this is achieved, you have the right capacitor.
The reason you use two volt meters is that this test should be short in duration, as quick as possible not only for safety but as the readings will change as the windings heat up.
A word of caution, capacitors can explode when line voltage is applied therefore cover the capacitor with a cardboard box or something.
Roger
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
532
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,528
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,659
Hello everyone, I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions: The...
1,399
Good Morning , I should know this , but will a 3 Phase overload trip if a 3 Phase motor runs single phase for a long period of time ...
2,190
