Koncarevac
Hi, I have a problem. I am supposed to control gas flow by an automatic motor driven valve. The valve receives 2 input signals, impulses for open and close respectively. I am using a PLC Function Blocks diagrams for the ABB RTU560. There is an analog PID FB, but I need to process its analog output control signal to get a three position control signal. The thing I need is a PWM block, which I don’t have implemented in the PLC.
Does some one have an answer to my problems? A hint how to make my own PWM block?
