Simon,
I'm afraid it's not that simple. I've never been able to simply remove the BE instruction, but then it has always been with Step5 V5 or before. I always had to replace the 6500 machinecode in the memory with an 0000 (NOP 0) code. But because bit fiddling is only to be performed by someone knowing what he's/she's doing, I won't go further telling how. It's way to tricky. If you're only mistaken one memory location, it might make the complete PLC unuseable. I would never do this when I'm under any kind of pressure, just because of the high risk involved.
Kind regards,
