DC Power Supply Alternative
rsdoran
Apr 2002
Birmingham, AL
7,371
A standard computer power supply can be found for less than $30 these days and can provide 24vdc @250 watts or more, it can also provide 5, 7, 10 and 17vdc. It can also be converted to be a variable supply.
The wires:
Black = common (0v)
Red = +5v
White = -5v
Brown = sense wire (connect to orange
Orange = 3.3v (do not use, just connect it to the brown wire)
Yellow = +12v
Blue = -12v
Gray = LED (go thru a 330 ohm resistor)
Green = power ON (can be attached to a black wire or put thru a switch).
The older ATX are slightly different, I will eventually show the details on a page.
I have this posted on the patchn.com forum in Tips and Trick and plan to add more information about this on the site. Many people and businesses have old computers laying around so if a need arrives for DC power supply they can be used. They also make a good test bench supply and can be converted into a variable output.
I've got about 5 old power supplies sitting around, some AT some ATX. How exactly do you get 24V out of them? Thanks for the good information.
On older units you had 2 connectors, P8 and P9, that went to the motherboard.
1 Orange "Power Good" P8
2 Red (XT No Wire) +5VDC P8
3 Yellow +12V DC P8
4 Blue -12V DC P8
5 Black Ground P8
6 Black Ground P8
7 Black Ground P9
8 Black Ground P9
9 Black Ground P9
10 Yellow -5V DC P9
11 Red +5V DC P9
12 Red +5V DC P9
The power connectors;
1 Yellow +12v
2 Black Ground
3 Black Ground
4 Red +5v
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
210
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
590
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
440
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
244
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
691
