RSView32 & Wonderware Intouch Install Question
markhommer
Jan 2006
Wichita,KS
Last year, I tried to install Wonderware Intouch on the same laptop that I had RSView32 installed. The two did not play well together (DCOM conflicts) and I had to reformat my harddrive to resolve the issue. Has anyone else ran into this? I have a project coming up that requires Intouch so I need to install the software but I'm hesitant. Any ideas or solutions?
Thanks in advance.
Mark.
Yeah I had the same problem. I contacted wonderware support and they emailed me this dcom file that I ran right after installing wonderware. Just make sure you dont reboot your computer until you run this after installing.
It wont let me upload the dcom file because it is not the correct file type.
I had a similar problem when installing Intouch 9.5 sp1 on a laptop with RSviews studio/ME 4.0. Intouch ran fine but RSV studio would crash after the intouch install. System restore fixed the problem but that was not a solution since I needed intouch as well. I reloaded intouch and then reinstalled Factory talk automation platform and that seems to have worked.
Just a heads up to anyone who needs both.
Marc
Hmmm .... I've had both on my computer at the same time without problems. InTouch would have been more like version 7.x or 8.x at the time and RSView Studio 3.x, along with RSView32.
I'm in a new job since then, but even now I have IT9.5 and RSView Studio 3.x. So, that's two different computers that I've done this with, plus at least one other engineer in my last job would have had the same setup.
Have I just been lucky??
Found this out today, problem on Dell laptop
Uninstall Embassy trust suite and also there is a AB Tech note on this issue with a registry edit that fixes the DCOM registry.
Wish, I would of found this out, before having to reload windows....
hey frnds will you please send me any link to download intouch from internet please urjently required demo version will b ok
hi friends...i am familiar with wonderware intouch 10 now i want to use rsview32 but i dont have much idea about that...is it possible to write...
3,681
I've seen references on discussion boards to a utility to convert screens from Wonderware to RSView32. Anyone done this? Experiences? I've yet to...
5,056
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
602
