jasdhillon
I am going for a control Engineer's job interview and I have been told that there will be an assesment test. Any one with ideas what could be in a test like this. Any help will be greatly apreciated.
Ken Moore said:You are in charge of a controls project, that is over budget and past due, what would you do?
brucechase said:1. Blame the purchasing dept. for not negotiating better prices and better delivery.
2. Blame the contractor for job delays.
3. Blame your management because you originally told them it would cost $xxx dollars and take ttt time and they arbitrarily cut 10% of the budget and shortened the schedule (called rush-up) by 15% without letting you know.
4. Blame the production department because they did not give you all the information needed when you designed the job (oh didn't I tell you I wanted a robot to pick and place the product?).
5. Blame the supplier of the equipment because the salesman promised that the capabilities of what you were buying were more than adequate (Our new motor starter has builtin ethernet/plc logic and a PC for controls and it's only $100).
6. Take vacation.
7. Study interview questions and start looking for another job.
DJM said:1. You have a P to I Transducer 0-100 PSI in, 4-20 mA out. Your pressure is 10 PSI, what is the mA output?
5.6ma
2. You have a load cell rated at 3.3 mV/V with 10 Volts DC Excitation applied. What is the maximum signal value to be expected from this device? What are the sense leads for?
33mV. Regulation of power supply.
3. Define Inductive Reactance? Resonance? What is the formula for Xc?
Reactance is an opposition to current change in an AC ckt.
Resonance is when the natural frequency of a ckt matches the frequency of the signal applied.
Xc = 1/2pifC
4. Can you apply (explain) Ohms Law? Kirchoffs Law?
One amp flowing in one ohm resistance will create a one volt potential difference.
The algebraic sum of all voltages in a loop must equal zero.
5. Can you explain (illustrate) a half wave rectifier? Full wave? Draw it correctly to have a positive or negative output? What are the advantages of a full wave bridge over a full wave rectifier?
Half wave rectifier obtains a wave every half cycle.
A Full wave rectifier obtains a wave on both halves of the AC cycle, there is less ripple.
6. Can you convert binary to hex to decimal? Do you know your basic logic gates? Flip flop types?
Have to think about converting, yes.
AND, NAND, OR, NOR, Exclusive OR.......
Flip-flops? You mean multivibrators? Which ones? S-R, J-K, ...
What I've found is that most companies look for someone that has very strong basics. If you remember the little stuff, you can very probably solve the big problems.
rsdoran said:Had to think about resonance and gave basic answers but there would have to be more to a test for an engineer. If I had been drawing the rectifier ckts it would have explained more.
