Siemens S7 and ABB ACS800
Stiffler
Sep 2006
Tonsberg
Hi all, I could really use some help..
I'am new to programming S7 and I wonder if there is anybody out there who could help me with a sample project for controlling ACS800 frequency converters via Profibus. I have Installed the apropriate gsd file. (ABB10812.gsd for DPV1, PPO type 4)
I want to Start Stop the converter, change setpoint, get torque feedback and so on...
Thanx
I believe there is an example project for a MasterDrive converter controlled over Profibus which would do as a start (do a search on this site). The Step7 project will not tell you how to program the ABB drive to react to the telegram contents though - the ABB manual for the Profibus card will help you do this.
Look in the downloads section under siemens, the file is Ppo_4_bl.zip
Thanx alot Simon, I have downloaded the file and it seems like it was a little bit easier than I thougt... I can understand better how the communication between the ACS and S7 functions now.:)
I have downloaded example project.
When I open project there are blocks:
-Cyclic OB
-Drive_PPO4_All_Words
-Drive DB
-DPRD_DAT
-DPWR_DAT
but in Symbol editor of the project there are few more defined blocks:
-UDT_DRIVE_STATUS_WORD
-UDT_DRIVE_CONTROL_WORD
-BLKMOV
-Micromaster_Drv_Block
-SMVRT_MD
-PPO4_DRIVE_BLOCK
Is project corrupted, badly downloaded or simply those block are defined and not coded.
Thanx
-Cyclic OB
-Drive DB
-DPRD_DAT
-DPWR_DAT
-BLKMOV
-SMVRT_MD
-PPO4_DRIVE_BLOCK
Thanx
You can get rid of these symbols
-BLKMOV
-SMVRT_MD
-PPO4_DRIVE_BLOCK
Just drop the FB into your project and it will work fine- I have an ACS550/800 FB with the correct names for the block I/O if you have trouble modify this block
Jay
Hi Simon, i'm searching for the Ppo_4_bl.zip file. I can't find it in the Siemens download section. Can you help me to find it ? Thanks.
DZL
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
469
Hi to all , can anyone explain to me how can i control DC and AC drives ( ABB DCS 800 and ACS 850 ) from a Siemens CPU using Ethernet or profibus...
6,999
i am new in robotics programming and configuration. this is completely education project talking to ABB robot with devicenet option irc5...
1,957
Hi I'm trying to read data from a ABB M2M from at Siemens S7-1500 plc by Modbus, however I can't seem to find the starting address in the M2M...
1,819
I have a Siemens S7 300 CPU 315-2 PN/DP PLC and CP 342-5. IM Module is configured via ethernet port. I have two profibus network. One on CPU and...
4,173
