Hello all.
We use alot of Moeller smart relays (same as PICO)for basic system logic. The timers within can easily be selected to time in seconds,minutes or hours including a decimal place to allow an entry of 1.1 which could be for 1 and 1/10 of an hour or 1 hour and 1 minute, or ETC.
We also use alot of AB micro 1K to 1.5K (and some SLC500). I have a program I allways use with AB that has a timer(TON). The value to the preset(PRE) is moved from a location written too via a micro300 panelview as well as the panel view reads the accumulated (ACC)value. This is allways done in seconds (0-9999 seconds). Customer now wants to enter values in hours and tenths (1.5 = 1&1/10 hour)0.- 24.9 hours.
The only way I know is to use a combination of counters and timers to get where I need to be. The obvious problem to me is it takes alot of "jumping" around to get from an entry at HMI of 1.1 to an actual timed value of 1&1/10 hour. The bigger problem is there are multiple areas in my program monitoring the status (EN & DN)of the original seconds timer.
Does anyone know of an easier way to have a timer set up following the criteria I mentioned above?
