Siemens OP3 and OP17 - upload?
misamark
Oct 2006
Malta
55
Hi to everubody!
Excuse me for asking maybe silly questions, but I am very new in this area; Until now I have never work with Siemens HMI;
I have on the process instaled 3 pcs of OP3 and one MP17 HMI`s; and I need to make secure copy of programs inside; but I am not sure that is possible;
CAN I UPLOAD FROM THIS TEXT BASED SIEMENS HMI?
I tried to establish serial and MPI communications bud doesn`t sussceed. :(
Regards!!!
Hello misamark;
To refine STL's answer:
OP3 is not supported by Prosave; MP170 is; but whatever you upload from the panel is a compiled file. You cannot open it in protool/WinCC flexible, and you can only download it (with prosave) to a similar panel, in case of replacement, for example.
Hope this helps,
Daniel Chartier
Thanks to everybody;
I tried to connect with ProSave, and I have seen that JUST OP17 is supported; But there is also one option in ProTool to UPLOAD from HMI; but no listed which OPs; so I have tried to make new project on OP3 and to upload, but without success; I still didn`t tray with OP17; I don`t have 15-pin serial cable to connect; I would try with MPI latter;
To dchartier: I know that I could not open and use this file to change project, but I only need secure copy to download in spare one; I have just one istalled and have one more in spare parts store; so I just need original one. That`s the same like AB, just upload and download, without decompilling and making changes. Unfortunatelly, I do not have original project with me.
Sure that You helped me so much, and thanks for everybody!!
do you know any supplier for the op3 membrane? we only need the membrane with keys, as a spare part...
1,241
I have OP3 and i want to Upload data from OP3 to PC , i'm using Protool , and i can make Download to any New OP3 , but the one that contain Data ...
1,642
I am having a simatic op3 siemens hmi, in order to communicate with pc what are the cables I should purchase, do I have to install any drivers...
2,200
by trial i can change the OP3 ProTool screen to OP73 WinCC Screen and download the new screen to OP73:wizard:. I want to ask if it's possible in...
4,585
firt of all thanks for your answers; I need information about how can I upload the program from op3.As I know I can manage that with protool and...
5,922
