Serial cable for Siemens OP 17 HMI uploading
misamark
Oct 2006
Malta
55
Hi people!
Do anybody have drawings for making serial cable for SIEMENS HMI, exactelly OP17. I have SERIAL RS232 cable but 9-9 pin; and I need 9 pin to PC side and 15 pin to HMI OP17 side.
Regards to all
MisaMark
Download program
You can buy it from Siemens or can make it with the conection in the attached PDF file.
Hope this helps,
Kelkoon
Hi misamark
Did u upload the project successfully. I thing u can upload the project using prosave only.
i use this configuration for the cable:
PC (9 pin) OP17 (15 pin, IF2 port)
2 -> 4
3 -> 3
5 (GND) -> 5,10,12
it works. before using prosave, turn off OP17, pres ESC and Up key, turn on OP17. wait a second, release the button. the screen will show ready to transfer. run prosave.
I tried many times but i couldn't upload project using protool.
But i use the above PDF configuration cable(6XV1 440-2KH32) for download.
Hi, this configuration works for Siemens OP 177B? I need a serial cable for OS transfer. I only have USB cable and MPI, and this sets dont work to do a complete low level restoration.
I use the S5 programming cable on a Siemens PG.
The cable has a 15pin on the HMI download side and a 25pin on the PC side all that is needed is a 25 to 9 pin converter.
Do the Horner adapter RS 232 to snp adapter could work on that plc to go online with my laptop and Proficy ? HE693SNP232A with a IC200CBL001A I...
1,985
Hey all, I know this is a shot in the dark: I'm trying to setup a redundant pair of ACM controllers and I dont have any of the serial cables for...
1,158
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,262
Hello, Does anyone have the Triconex Tristation serial cable pinout? The cable part number is 1600080-0xx.
1,157
Im working on setting up a 2D barcode reader with a RS 232 cable back to the PLC. An engineer is requesting they want the bar code reader on a...
3,416
