I'm trying to find a good way to measure the level of liquid in a tank full of solid particles.
In comparison, this application is very similar to a salt brine tank on a water softener. A perforated bottom level in the tank with a pump pulling off below that, and solids above the perforated level.
Currently, there is a pressure transmitter on the bottom of the tank below the perforated level.
The problem being that sometimes the pump pulls liquid out faster than it drains through the perforations and skews the level reading. I've thought of a 'stilling well' with similar screening to prevent the solids from moving into the pipe.
Any other ideas out there?
