slc 500 cheap com
astronutt
Feb 2007
home
17
I have a slc 500 with 5/05 proc. I have a compaq laptop no serial port I bought a belkin usb to serial adapter but the serial part is male my proc needs female will this work with a male/female adapter or not.I guess what i really need to know is .....what is the cheapest route to comm to this proc. Please include part names or if the usb to serial i have will work and what i need to connect.
thanx
SLC 5/05 -- Use ethernet. If you don't have an ethernet switch/router/hub, then use a cross-over cable.
That's my choice too but if you don't know the processor's IP address, you'll need to connect with the serial port to set or view it.
I'd be curious to know if the 5/05's Ethernet port defaults to using BootP to acquire its IP, as the Micrologix 1100 does. If so, you could use the BootP server that comes with RSLinx to set the address... and bypass the serial port altogether.
The 5/05 does indeed default to BootP, but if the IP address has already been configured and is not known by the OP then stick with serial. Of course you could wipe the memory and start fresh but perhaps they want to keep the program already in the controller.
I use BootP all the time personally, but if you are just getting started, serial is the easiest way to go.
As mentioned, a simple null modem cable or adapter from Radio Shack will do the trick easy enough.
OG
Hey all, we are trying to find a simple cheap display that would display errors for our machine run by an SLC 500 PLC. We have on HMI on one side...
29
12,800
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
979
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
775
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,368
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
565
