go online slc 500
astronutt
Feb 2007
home
17
ok i made a cross over cable i am connecting a non serial laptop to a 5/05 slc proc anyone tell me what or how to config drivers to go online?
thx
what do you mean by a non serial laptop? what you need to do is start up rslinx, click on the communications tab and then configure drivers. click on the drop down box underneath available driver types and select rs 232 df1 devices then click add new. once it shows up underneath configured drivers highlight it and select configure. just hit auto configure then it should set it up for you.
Good Morning , I need to make a online change to a SLC 500 5/05 . Is it safe to turn the key from Run to Remote with causing the processor...
1,875
Good Afternoon, I'm trying to do online edits on a SLC 500 5/05 . After I put my instruction in , I keep getting " Test Edits Failed " ...
3,755
Do I was able to configure a driver and get online with the plc and found an original program error from 1995 which they would have never noticed...
5,361
Good Morning , I have a SLC 500 rack with a 1747-L542 CPU and 2 DeviceNet scanner cards. I am having a terrible time going online with this...
4,365
I'm having problems with a SLC500 that usually will kick me off line when I try to do a on-line edit. Last week I wanted to change XIC to a XIO...
20,165
