ASCII Commands in RsLogix500
Big John T
Nov 2006
Poplar Bluff
199
Is there any way to sequence the read write to port 0? I need to write a string out and wait for a response to come back then write another string out and wait for the second response the do a compare to see if it is what I am waiting for.
Do you have to clear the buffers before using AWA? Any demo files that I can look at would help a lot.
John
John
see if this answers your questions...
Edit: see if this helps :D, I have four different possible strings to write/send and looking at the response from the servo, to enable the rest of the logic or not
Thanks for the example file... Now I'll chew on that a bit...
Edit: The biggest thing I see is your using a OSR in front of all the ASCII commands...
Let me give that a whirl...
John
In addition to the one shots I had a defective communications cable. Trying to learn something new with bad equipment will make you pull your hair out...
Thanks again for the example file.
John
Hi
When i tried to check ARD instuction in RSlogix500 then it shows me error that my communication mode is "SYSTEM" and when i tried to resolve that i seen that for READ instruction i must put my communication in "USER" mode
I tried to make it USER in channel configuration, but when i assign USER Mode then my total communication was lost and to re-communicate i need to clear CPU memory by removing battery and discharging it's capacitor
so please tell me procedure to use Ascii read command
Thank you
I'm having some trouble getting this code to work. Currently I have a Ladder Logic version working perfectly. I converted the Code to Structured...
1,874
I have a current source and I want to control the output state, the voltage setpoint and the current setpoint. Also I have to monitor the current...
2,505
:wish:Hello I want to sent the commands attached from PLC to DMX Controller.When i00 command is sent it replies as shown as fig in hyperterminal...
2,056
Hi, I am trying to get Allen Bradley Micrologix 1400 to send ASCII commands over a RS-485 2 wire connection. I can get PuTTy to communicate just...
9,092
Hey Everyone, I'm trying to communicate to an external device using ASCII Read and Write commands with RSLogix 5000. I need to Write an ASCII...
3,526
