how to create a multiple instance db in step7?
notfish
Apr 2003
i know how to create an instance db in step7,but when i try to create a multiple instance db for several fbs,i found out that in the dialog box,i could only choose one fb to be referenced.
can anybody help me?thanks!
notfish,
let us suppose the following:
  • we have FB1 which controls star-delta switching of a motor
  • we have FB2 which the left-right switching of a motor
  • we want to do stardelta switching of Motor1, Motor2 and Motor3
  • directional control of Motor4 and Motor5 have to be established
Create a new FB, let's say FB3. In the declaration table, put the STAT variables Motor1, Motor2 and Motor3 of type FB1 and Motor3 and Motor4 of type FB2. These are the multiple instances.
In the networks, place the calls to the multiple instances Motor1 to Motor5 and fill the parameters in.
Place a call to FB3 in OB1 and attach a DB to this call. This is the multiple instance DB.
I have attached this project as a zipped external source file, so you don't have to do the typing.
Kind regards,
Jean Pierre Vandecandelaere
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
166
How to Copy multiple LD function blocks of Proficy Machine Edition PLC project and create their text files. I need to do this because I want...
2,464
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
262
Good morning to all, I have the following issue, I installed everything of intouch including the patch, it is the 2023 version. The...
342
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,138
