Quantum 140 CPU 113 03: not connecting, blinking RUN light
OZEE
Mar 2006
Kansas
1,695
Problem with Quantum 140CPU11303. I've been unable to connect with programming terminal and the panelmate cannot connect. This system has been running for several years, but a power blip today shut it down.
We had no indication that the battery was down so I'm hoping the program is still in place (we do have a backup, but if I can't connect...) When power came back on, we replaced the battery anyway.
Using ProWorxNT, when I try to go online directly to the procesor and scan the network, it finds nothing. I am able to connect to an identical processor literally right next to it using the same computer/cable/configuration, so I don't think that's the problem.
The "RUN" light is blinking in patterns of 7. I'm assuming this means something, but don't have access to any manuals at this location.
What does the blink pattern mean?
Where can I find an online manual to explain this blink-code? So far, I've been unable to find anything useful at the tele website... (Now I remember why I really disliked Modicon...)
Sorry can't help with a link...I had it on my hard drive.
So I've uploaded it to the guest area of our site.
I'll PM you the login details.
Hi all, Yesterday I tried to reset the Quantum 140CPU65160S controller by pressing the Reset button available on front panel under the cover...
2,569
I need Help !!!!! We are having Schneider Quantum 140 CPU 113 03 working in redundant mode, installed in 2006. I have no backup or Schneider...
2,273
Hi, I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The...
4,548
Hi Every one 1) I am using Quantum CPU 140 434 12A, Which has got two modbus comm ports,with XXMIT EFB and RS-232, i successfully communicate to...
5,138
Hi, First of all, thanks in advance for those who support and advises. I have a Modbus/TCP operational network as shown below. However, at any...
914
