I'm currently working on a project for a client that requires me to convert standarized templates that were created in RSViewSE Stand Alone to RSViewME. This has been challenging duplicating the GFX since SE will not convert to ME, but I am making headway. The problem I'm encountering is passing parameters to the "canned" faceplates. See pic below for explaination.
Currently I have a transparent Goto display button on the Analog Indicator on the right of the picture above. When someone presses the indicator it opens the Analog Faceplate (Middle). If someone has the security the Goto display button "..." will be visable and when pressed will open the Analog Configuration Faceplate (Left).
Currently I'm looking at 200-300 Analog Inputs alone and every one will have to have this functionality.
I can recycle the Analog Faceplate by using the Parameters file to pass values in a placeholder. My question is how do I pass that initial parameter along to the Analog Configuration Faceplate. In other words, I can get one level of parameters to pass along to the first faceplate fine and dandy, but trying to figure out how to pass parameters along to the second faceplate is leaving me stumped. The thought of having to generate unique Analog Faceplates for every input is taunting.
If you can offer up some help or advice, you'd make my day!
Thanks in advance,
Bobby
Thanks in advance,
Bobby
