Just a note, there is almost no reason to do this on a Logix based platform, unless you are particular about having 0 minor faults.
Overflow does not cause a major fault at end-of-scan as it did in the PLC/SLC series.
I ususally track down the cause of the overflows (usually an un-checked divide, that may divide by zero), and then manually add bounds-checking to prevent the occurrance. That to me is a better solution, as I can also then set some default or safe value.
