scaling an analog input on Siemens CPU315
mlmccauley
Nov 2007
Dallas, Texas
I'm essentially new to Siemens (the last time I programmed one, the development app ran under DOS). I'm programming a CPU315-2DP in LAD. The program and the program structure is very simple, and I'd like to keep it that way. Is there a *simple* way to convert a word (IW) variable derived from a 4-20 input to engineering units i.e. a simple zero and span conversion?
I'm using Step 7.
Thanks!
Mike
LIV said:
Fc 105 "scale"
Thanks for the quick reply.
What threw me off on FC105 was that, in "Help", it stated that fuction is for processing input from the 6ES5 464-8Mxx series of modules, and my AI module is a 6ES7 331-7KF02-0AB0. Will FC105 work with that hardware?
Thanks again,
Mike
Mike,
It sounds like you are using the wrong FC105, you need the FC105 from the Standard Library in the TI-S7 Converting Blocks folder.
Dear all Iam using three load cells connected in parallel to calibrate the weight of a product but in don't have a weighting module in my...
3,506
Hello everyone, I have a plc 5 input card receiving an input from a conductivity Transmitter where 0ma=0 uhms and 20ma= 20,000 uhms The raw min...
3,663
1,838
Hello! I am new at PLC programming. I am using TM221CE16R PLC with TM3AI8 analog input module and SoMachine Basic v1.6. I am trying to scale...
7,112
Hello, I have a Micrologix 1400 PLC and using RSLogix 500. Using a Multi Ranger Ultra Sonic Level Sensor and the input is moved to N7:11, then...
3,935
