I have a zen 10c1ar
jaymmzzs
Jan 2008
burn
18
I am trying to program this but really having a hard time.
What I need it to do is to turn on switch a,b,c, while switch d is off
then leave a on turn d on while turning b,c off
then i need it to leave a on b on c off d off and close e.
i would also be looking to add time to the functions perhaps 30 sec. for the first set then 90 sec then 30 for the final.
I would really love some help on this.
If you need more info I have it here.
ZEN's are fun little micros.
I am guessing switch a,b,c,d are outputs?
usually switches go to inputs.
I am stuck doing the grave thing this week, I will help you when I get there in a couple of hours.
I have included the schematic below,
what I need is for a one button push operation, if you look at the schematic you will see that it is a toggle switch.
I need to make it a one push start .
So I will need 9 and 17 to close
28 and 21 to close
21 and 22 to close
2a and 5 to be open
after the dumper gets to the top
I will need the packer to start , with the dumper staying at the top.
To start packer I need 9 to 17 to stay closed
28 to 21 to open
21 to 22 to open
2a and 5 to close
after say 90 seconds I need the dumper to come down
so I need 9 and 17 to stay closed
28 and 21 to close
21 to clsoe with 23 and then it is open from 22
and 2a and 5 to open
Then the unit shut down until the button is pressed .
Jpeg for comments
Well I was going to post a pic of the logic so anyone could make suggestions but the pic didn't print. I tried to do it again but I get a message that it is already there. sorry
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
135
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,043
This hasn't become my problem yet, but it may soon... Ancient PLC-3 (yeah, I know) has been humming along for decades. It now has some analog...
2,479
I need to print data produced by the program PLC (Beckhoff PLC) from a Citizen PMU 2300 printer. More precisely I need to send the data to the...
4,014
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,604
