PV600+ & Printing
scottmurphy
Oct 2004
363
Simple question.
Can a printer be connected to a PV600, and be configured to print out data?
I am proposing to use a panelview instead of a chart recorder for this project, but have not been able to get a direct answer as to whether or not a printer can be connected & configured to do what I want. I know it is possible in other platforms, but the customer has specified AB.
scottmurphy said:
Simple question.
PV can only print alarms
I believe that it's only possible to print a screendump, sorry
This may work, if you could configure the PV to display the
log data to be printed, then use the ol 'printscreen' function?
Bugger, any suggestions to acheive what I want. Maybe by writing
to a flash card, then using PC to print instead?
The only "printing" feature in the PanelView Plus is a screen print feature. It works with USB or TCP/IP connected printers that support the Hewlett-Packard PCL 3 printer language.
Another method I have used is to load the KepServer Enterprise "User Configurable Driver" and use it to drive a serial-connected printer using ASCII protocol. It requires more work to set up and isn't as smooth as I'd like, but it does work.
Are you looking for a line-printer sort of output, or PDF file output, or some sort of graphical screendump ?
the only "printing" feature in the PanelView Plus is a screen print feature. It works with USB or TCP/IP connected printers that support the Hewlett-Packard PCL 3 printer language.
Hi ken,
I am looking to replicate what a chart recorder is doing, except not printing continuosly, end of batch maybe.
Can the screen print method be done directly from the PV itself?
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
437
Hello, I've recently tried to upgrade my PLC controller from a L72 to L84ES and everything seemed to work, all buttons and screens as far...
2,677
I imported the pva into Factory Talk View Studio and it gave me some errors. Alarm message Ack option not supported. Blinking color images are...
1,798
I'm trying to set the date and time on a Panelview 600 plus 2711P-T6M20D8 SER A. I looked for a white square to pop up in the lower left...
1,818
Hello forum, Simple question from a newbie. We have a PV600 showing all nodes in error. The Link coupler power LED is not illuminated and a...
2,028
