Panelview to Micrologix Comms
Aftech
Sep 2008
Bonnievale
18
Hi Everybody.
I want a panelview plus 600 to communicate with a micrologix 1100 via ethernet. Can any one give me some advice on how to set up the communication on the panelview ??
Do I have to connect the panelview and the ML1100 to set it up ?
Aftech said:
Hi Everybody.
Yes they must be in same network to add ML1100 in shortcut menu. Configuration for PV is in RSViewME > RSLinxEnterprice tab
I do this all the time with a C-More HMI to the 1100. I use a N-tron din mount ethernet hub. The PLC and HMI connect to the hub. As long as you have assigned valid IP addresses for each device you are good to go.
If you know the IP address of the controller you can simply go into the Panelview configuration screen which runs at power up and set the address there. When your screen is programmed you then set up the communications in the project itself, under comms tag I think from memory, where you define processor driver, IP address, connection method etc.
146
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
909
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,790
Hello Everyone, Please forgive me for some of my ignorance, I am relatively new to the PLC community. I am setting up a machine monitoring...
2,174
Hi PLC People, I get the following error when trying to compile a Panelview Plus 7 Standard program Using View Studio V10.0 Device Shortcut is...
4,904
