@bopol:
Yep, i also finished my tests with the 750-881.
Your addresses are correct, with the exception, that i have to add +1 to every address to hit the right address in the WAGO. For example to read from address 12288, i have to use 412289 in AdvancedNMI.
If you wanna write to your WAGO, you have to ask Archie for a patched version of the driver DLL. The actual one seems to have a bug. I tried to write/toggle a single bit register at address 12288 (or 12289), and my VB-Application always crashed.
To write, you have to use the same address as for reading (example: 412289). At least that works for me.
Daniel
