I've had a look around but haven't found a quick setup guide or anything akin to that.
I'm after what sequence things need to happen, and what software is required etc to get the PVP loaded, then configured to communicate with a compact logix cpu via serial.
Panelview plus 1250
From what I have read so far, It either needs to be setup via card or serial initially, and ethernet isn't available until this is done. Also, I gather factory talk is the comms software needed here in lieu of RSLinx for the setup.
Please forgive my ignorance, this is all a little new to me ... seems less intuitive than the siemems stuff I'm used to. But no doubt its all just a matter of familiarity and the associated mindset.
Cheers.
Panelview plus 1250
Cheers.
