What the difference of encoder absolute & incremental
zai_jnr
May 2008
MALAYSIA
169
Hi everyone,
Really need to know what the difference between rotary encoder absolute type and incremental type.. Make me feel crazy to find the difference between this type o_O....what output phase A,B,Z in incremental encoder? How to use this signal..everyone know this matter..can share with me? :(....10Q
Hi everyone,
Think of an incremental encoder as serial, and absolote as parallel.
Think of incremental, YOU have to figure out where the encoder is, and absolute IT tells you where it is.
Incremental after a power failure, you no longer now where it is, absolute after a power failure still knows where it is.
Incrementals give you a pulse train indicating units of movement and direction. An absolute gives you a binary bit signal scaled in bits of resolution for one encoder shaft turn.
With an incremental encoder, you will always need a home position sensor.
Most applications I have seen incremntals on linear motion to move an axis, and absolute on a master gear of a machine to indicate where in the in the rotation of 360 degrees the machine is at.
For myself this is my view on these 2 encoders.
I use incremental to tell me how fast I am getting there. Absolute tells me where there is.
Another way: Incremental sends me a pulse for movement. Absolute sends me a word.
Mickey, curlyandshem, bits n bytes, clay b......Thanx a lot for your feedback and reply for my question..your article and info really help for...thanx a lot... any one still one to add more info for this question?:p he he he ..
Bits n bytes,
I cannot open your link info..received file already corrupted
I just verified that the link does work. Try this, "Right Click" on the link, then in dropdown box, "Left Click" on "Save Target as", instead of opening the file, might work.
Hi Zai Jnr,
Incremental: means you will count the pulses,
and every pulse is the same.
Absolute: means every pulse has got a unique code.
The pulses can be coded in for example Gray-code.
So every position is unique.
What is the difference between a Hyperface Encoder and an absolute encoder. I am thinking of changing our Lenze motors to SEW , but keeping the...
13,200
HI every body I have in my work a more type of machines which uses (RESOLVER) and the other one uses (ENCODER), but i know the concept of...
19,833
i want to know the difference in teco and encoder functioning. i have some servo motors in which teco is connected for motor control. some motors...
3,508
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
747
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
700
